- CA_TravelerExplorer IIIMaybe fabricate a metal frame for the basement ceiling to bolt it to would help solve some problems???
- Colo_NativeExplorer
CA Traveler wrote:
Mine was installed upside down in the basement and bolted to a metal frame.
Can't you just use large washers or even a metal plate under the bed?
That's what I thinking. I have a a plate that I was going to put against the floor joists and then use big washers or 2' flat bar for extra support. You by chance have pictures of you install? - CA_TravelerExplorer IIIMine was installed upside down in the basement and bolted to a metal frame.
I believe mine uses 6 bolts. - Colo_NativeExplorer
GordonThree wrote:
What's your concern? Mine isn't upside down but sideways. Been like that three years now.
The main concern is getting the 6" air space. It looks like I will have to put it in the basement and if I hang it upside down(which is approved) I will have the clear space and it is out of the way but the dang thing is 55 Lbs. hanging from 1/4" bolts and I just wonder hanging from the basement ceiling also the floor under the bed is going to be a problem - pianotunaNomad IIIMagnum is pretty specific in the owner's manual about what can and can not be done as far as installing.
- GordonThreeExplorerWhat's your concern? Mine isn't upside down but sideways. Been like that three years now.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
