Smitty77
Apr 02, 2018Explorer
I did a little test today. Unplugged the coach from the 20A shore power. Turned on the Convection Oven to preheat to 450 degrees, and also a 1500W heater.
BMK-Meter - indicated a steady 220-223A draw.
When I go back to the Inverter Display mode, it indicate status of Inverting, and reflected 185-187A. Which I assume is the current Amp draw.
On Edit: I forgot to share the values when I turned back on Shore Power and Charging had started up again.
BMK-Meter - Reflected 124A going in
Back to the Display - Indicated Bulk and 92A
This is the differences I mean between Meter/Remote Display and BMK- Meter values. (I call it this, Meter Display, because you hit the ARC-50's 'Meter' button to either display current Status (Bulk, Absorb, Float, Inverting (When no shore power.) etc.), or choose BMK or AGS, etc.
I'm preparing a lists of questions I want help on qualifying and understanding before making contact with Magnum to review:)!
Best,
Smitty
Best,
Smitty
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
