CA_Traveler
Apr 02, 2018Explorer III
Smitty77 wrote:
BMK-Meter - Reflected 124A going in
Back to the Display - Indicated Bulk and 92A
The BMK uses a shunt on the battery terminal and should have a accurate value of battery amps.
The display is trying to indicate how many amps the Magnum is outputting and this value is the sum of amps that are used by house loads and battery charging. Note that for very low house loads then most of the charger amps go to the battery.
Then the Magnum display may also not be very accurate (mine is not) and my quoted post above reflects what I found out from Magnum.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
