dougrainer
Feb 25, 2017Nomad
Are you reading the MAGNUM remote panel? Or are you reading the Intellitec or PCS 120 EMS system remote. I will bet you are reading the EMS (energy Management system) remote and if so, that jump would indicate the Water Heater 120 element engaging (4 amps plus the 11 to 12 amps the Element pulls) ---16 amps. Once the 120 element heats the water, the element turns off and your voltage drops to that 4 amps. If this is NOT the case, I would look at loose cables on the coach batteries. Doug
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
