magicrider
Feb 27, 2017Explorer
Gents, my apologies for not responding sooner. The RV is plugged in my shop and I do not need to resolve immediately. My son is coming up this weekend and we will tear into it to check batteries etc. the unit is a Magnum ME series in a 2007 Fleetwood. Per the book if I select charge, it should bulk charge, then absorption, finally change to float if I read this correct. It never drops down on its own. I can select absorption with an indicator of flash once per second. The reading is DC and on bulk is 16 amps and 13.2 volts. If I switch to absorption it drops to 3 or 4 amps and 12.7 volts. I am assuming it never drops down from bulk to absorption to float on its own because of a problem?
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
