Houston_Remodel
Jun 13, 2015Explorer
1- Is this at your home or ALL campgrounds? If the wire feeding the circuit to the rv is too thin, you can't possible draw enough amps to run both. Or the wire could be faulty otherwise such as a nick underground. At the CG last weekend we could not run both. At the same CG but a different site we have had no problems. Our Progressive industries surge protector indicator panel showed low voltage available.
2- The AC may have a 'wait a few minutes' before restarting itself setting. Mine does.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
