wolfe10
Jun 13, 2015Explorer
Houston Remodeler wrote:
If the main breaker is tripping it means you're not drawing enough power into the RV
Perhaps a "rephrase" is in order:
If CG voltage is low, many appliances, including A/C's will draw more AMPS. This can cause the appliance(s) to draw more amps than the breaker was designed to handle and it will trip.
If you try to draw more than the capacity of the CG breaker (assume 30 amps) it will be the CG breaker that trips. Again, low voltage can cause your appliances to demand additional amps.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
