ktmrfs
Jun 14, 2015Explorer III
road-runner wrote:Wiz wrote:Sorry I missed that detail. If nothing changed with the first replacement I retract the suggestion. All I can think of now is to start measuring the current draw. Since the kill-a-watt is good only to 15 amps it would take making an adapter to break out a single wire from the shore cord to use a clamp meter. Maybe somebody else knows an easier way.
Are you suggesting replacing it a second time? As mentioned in the original post and once since, I replaced the breaker last year which does no seemed to have improved the situation. It's cheap enough though that I can replace it again if there is any chance it's defective.
missed it also. agree,
what I'd do is go to the trailer breaker panel and turn off all breakers but the 30A main, AC and microwave and see if the problem still exists. By code the AC and microwave must be on dedicated breakers with nothing else connected since they are high draw permanent installed devices.
If it still happens, then one or the other is drawing higher current than expected.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
