ktmrfs
Jun 14, 2015Explorer III
smkettner wrote:
Is the main and AC paired? I would swap the AC wire with the MW as both should have 20a breakers. Possible get a 30/15 and a 20/20 to have a low draw item paired with the main. Breakers are more sensitive as they get warm so having two high draw items together can build a little extra heat.
since it is a 30A circuit for the trailer I don't think this will have a effect. Unlike a 50A circuit this is a 120V single leg input with all the current going through one 30A leg, unlike a 50A where you can split the load between each 120V leg of the circuit.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
