Wiz's avatar
Wiz
Main breaker trips with A/C and Microwave on.->RESOLVED
My main circuit breaker trips if we start the microwave when the A/C is running. Today when it happened, I forgot to turn off the AC before resetting the breaker and the A/C wouldn't start. I turned it off at the thermostat, set the breaker, and turned on the A/C and it ran.
Rig is a 2000 Coachmen Class C 30 amp system with a Dometic rooftop A/C unit.
This started last summer so I replaced the main breaker:
T&B
Type TB 120/240 VAC
Cu/Al HACR Type UL
1 POLE SR-100
E162469
LR102619
A/C works fine by itself and the thermostat is set to Auto and Lo.
Do I have a capacitor or something going bad?
I'm pretty handy but don't know what to look for or where. Can I be low on Freon or whatever they use now?
Thanks!
-----------UPDATED 06/20/2015------------
The issue was originally caused by a 14-year-old breaker getting weak. It was accidently replaced with a 20AMP breaker instead of a 30AMP. This replacement breaker continued to trip because it was below the required capacity to handle the load and was working as designed. A 30AMP replacement is on order.
  • Turn the hot water heater to LP only and the refrig to LP and see if the breaker trips.
    Do you expect two high-wattage devices to run at the same time in your coach?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Now I run A/C and Microwave on 30 amps in most of the places where I'm stuck with30 amp (not all).
    One question: When was the last time you went, as the song is titled: Up On The ROOF,, with a tool kit and removed the covers from the A/C and gave it a good cleaning,,Epically the condenser?
    As heat incrdases and temp's in the system rise. pressure builds, the compressor works harder and harder and....... CLICK goes the breaker.
  • Jack_Diane_Freedom wrote:
    A 30 amp system will NOT run the AC and microwave at the same time. The breaker did its job.
    Ours run fine together,30A with a 13.5k a/c unit.
  • A 30 amp system will NOT run the AC and microwave at the same time. The breaker did its job.
Having RV issues? Connect with others who have been in your shoes.24,298 PostsLatest Activity: Aug 09, 2025
