ken56
Oct 12, 2019Explorer
Quite likely it is the capacitor and capacitors are easilly replaced. The bottom will be bulged out if it is bad. The bottom should be flat. There should also be a sticker on it telling you what size it is and it is important to get the same size (electrical rating). If you are able to do it yourself do it, otherwise be prepared to pay a couple hundred bucks for someone else to do it, a capacitor should only cost about 20 bucks or less. Google is your friend in this, look up how to do it.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
