dougrainer
Sep 27, 2017Nomad
if you had a leak in your new HOUSE and they stated they would install a small tarp over that area where the leak is, would accept that? While the slide cover is a good thing to have, installing one because they are unable(they could if they had the factory haul it back) to find to repair a defect, is not correct. LEAKS need fixed, not covered up. Doug
PS, They did not due the pressure test correctly if they could not find the source.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
