First, let me say that charging deep cycle batteries via vehicle charging system is very inefficient. And if you are using true deep cycle batteries (as opposed to vehicle starting batteries), you'll dramatically shorten their useful life.
1. Unlike vehicle starting batteries, RV deep cycle batteries are not designed to tolerate high amps - both charging and discharging. Trojan's T-105 (225Ah), for example, is rated @ 75A.
2. The vehicle's charging system is designed to briefly output high amps when it detects low voltage (discharged) conditions. As the battery voltage rises during charging, the output amperage proportionally decreases. Problem is, the vehicle charging amperage is much too high initially (typically 80-140A), then quickly drops well below the the most efficient charging amps for deep cycle batteries which is typically 25-30A continuous, but depends of course, on the battery's AH rating and ambient temperature.
MEXICOWANDERER wrote:
Wanna get exotic? Dig up a THIRTY OHM EIGHTY WATT RHEOSTAT, and wire that into the negative field shunt that you made to chassis ground. Now you are the boss, not a 29 cent chip. And NO it will not "hurt" the ECU unless you forget what you're doing and pass out in a hammock. This is FULL MANUAL CONTROL of your alternator.
With all due respect, I think this a very bad suggestion. You'd need to control both the engine RPM and field voltage. And if you inadvertently failed to closely and continuously monitor both battery voltage
and amperage, you risk, at a minimum, of destroying the battery(s). 'Exotic' to me, is reliable multi-stage regulation, specifically designed for charging storage batteries from vehicle alternators.
http://www.charlesindustries.com/main/ma_alternre.html
Most vehicle alternators have integrated regulators, so tapping the field is well beyond the abilities of your typical back-yard-wrench. And of those that have tried, the vast majority end up destroying an expensive alternator. If that's your goal, then spring for a 555 series Leece Neville with an external regulator - easy to by-pass or remove, without dissecting the alternator.
Since I rely on few 120Vac appliances I don't typically pack around an AC generator. I do, however, pack a portable DC generator. A 7 HP Honda coupled to a Leece Neville 24V alternator. But with solar, I usually don't need it on a regular basis.
