Merrykalia
Feb 12, 2014Explorer II
dhsmontana wrote:
Thank you everyone. Great suggestions and we can look Friday and let you know what we see. I did look at the manuals but unfortunately it doesn't give me enough info. We did locate another handle under the slider by tires black handle. Manual doesn't say what it is. I was afraid to pull it as I thought it is a manual lever to disengage the auto slider. Old biscuit I think this is what your referring to. I'm going to pull it. One question should it stay open? Thanks you.
I'm not Oldbiscuit, but yes, that is the handle. Make sure you are hooked up to the sewer and then pull that handle. You should hear it gushing out. If not, then that is not the problem.
Do NOT leave the handle open. It will allow sewer gases to get into the RV and it will smell awful, but also, it is gas, so there is always a slight possibility of an explosion. (yes, pretty slight possibility, but it is there).
I hope you find that this is the problem.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
