MEXICOWANDERER's avatar
Aug 12, 2017
Make Your Own Alternator Tester Cheap & Simple
http://www.ebay.com/itm/181473581583
Not charging at all, does not require a tester. A simple handheld digital voltmeter can easily spot voltage regulator malfunction.
But howabout "Is it good or bad?" maybe issues.
Th3 3 volt "ALTERNATING CURRENT" full scale on this voltmeter finds stator problems and rectifier problems in a flash.
Take meter out of shipping box.
Two wire connections to this meter. Three foot 18 gauge wire is enough. Buy a couple of alligator clips.
Clip any of the two wires to negative
Touch the other wire lead to the battery stud on the alternator
Higher than 1 volt on the 3 volt scale means there is a problem inside the alternator. Time to get a replacement.
Works on all alternators that are attempting to charge. You know how to tell if the alternator is totally dead, right? This will detect borderline "it's charging a little but not enough" grade problems.
  • Absolutely not recommended and strongly so.
    GOOGLE
    LOAD DUMP
    Second negative to cable disconnect testing...
    An open or short in a stator winding or in the rectifier bridge will cause PARTIAL charging. Well above the minimum needed to keep an engine running "with a battery disconnect"
    And THAT is exactly what this cheap tester does for a living - tests for stator and rectifier faults. A burned stator or compromised rectifier is a death rattle for the alternator. Want to find a problem now, or in heavy traffic?
    I was sitting in Celso's shop when a customer lifted a battery cable on a 2008 Ford Focus. "See the engine died" he said. He blew the ECU. He did not have the 300 dollars to buy a rebuilt computer. The last I saw of the car it was gathering dust. I am still puzzling why he thought he had a problem when the engine kept running with the battery disconnected. The genius had to have done it before and somehow rationalized it was a sign of a problem.
    What I wrote is not myth or hype. Sometimes an ECU can withstand a LOAD DUMP. Do you feel lucky? Some ECU's cost a thousand dollars and involve a several week wait. Did I discuss ignition key code reset fees? Or multiple ECU CHASSIS PROCESSOR failure?
    Please do yourself a favor and forget suicide theory. The cost of the meter is dead cheap. Using it is 4th grader complicated and you an impress the first person who you diagnose.
    The test must be conducted AT THE ALTERNATOR and not anywhere else in the system.
  • :) Hi, the easiest generator/alternator test is to start the engine and disconnect the negative battery cable; If the engine shuts off the charging system is not working.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
