SidecarFlip
Dec 05, 2017Explorer III
DAS26miles wrote:
I am going to make my own solar panel mounts using 2 aluminum 1 1.2" or 2" angle iron. Do I need the heavy 1/8" or will the thinner do? Reason I am asking is I will need to cut them to size and the upper portion may need to be ripped so as to keep the panel height down to 1 1/4 to
1 1/2". And I will be using a table saw if I need to rip or my 10" compound mitre saw wit 60 carbide teeth. It's an old blade and needs to be replaced anyway.
Little bit of a contradiction there. It's aluminum extruded angle, not aluminum angle iron, 2 different things and when you cut it, put the blade in backwards. In correct, dull or not, it will grab your angle and make a mess or injure you and we don't want that.
Better yet, use an hand hacksaw, much safer.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
