KangaBunnyRoux's avatar
Dec 29, 2020
Manual Carefree Colorado Awning issue
Folks, My manual awning will not click into the "spring tension - roll up awning mode."
I saw this addressed several times. Danged if I can get search function to give results.
It has a manual Carefree Colorado awning, no motor. It semi worked when I opened meaning I had tension in the spring system, pulled on the fabric lead lines to deploy, etc. The locking arm lugs were toast, and no amount of WD 40, nut buster etc would free them up to lock the arms. Or banging on them I might add. But I had spring tension until I hit the lock button.
With three days of 14 to 21 mph winds coming I decided to retract awning. I lowered the arms, hit "unlock" which memory serves as the point I should get tension in the spring, and the awning rolls up on its own as I hold the fabric guide rope/string/flat black lead.
I got nothing. No tension. I checked and rechecked all other pieces. Locked and unlocked the sliding button. Nothing seemed to unlock and then engage the spring tension to roll up awning.
Wind started picking up, I fought with it for 15 minutes or so, and settled on manually rolling it up, locking the arms to the sides mounted on the class A, and then using a good piece of wire to secure the arms at the top so wind doesn't get underneath and cause a parachute like drag yanking it open.
Am I missing a step? What did I forget or screw up this time? Is there something in the tube I can spray with silicone? Is that maybe "froze up"?
Been campings and deploying awnings for 16 years as a weekender. I am 59 days into full timing and I seem to break something or totally forget how something works every other day. SO I am by no means a Noobie. I am worse, a person who felt he knew his way around an RV and all the systems. Right now I am frustrated and feeling stupid.
  • Well my lock unlock lever seems to engage and un engage okay. If you are saying the internal to the tube part may have disconnected...I do think that may be what is happening. I've read horror stories about those springs under tension so wouldn't attempt that on my own. Is this something "whacking it with a hammer might break free? As I said the lever slides and moves the exterior mechanism quite well. But it has no effect on the "engaging tension" aspect I recall it having. At least I think that was what previously provided the tension and retracted the awning. It used to have a lot of tension. Now it is as flaccid as it gets.
  • It is possible that the lever is spinning on the release shaft. You would need to get up to the lever and move it while keeping harp eye on lever and shaft. Some can be fixed by using a self-drilling screw to secure it in place.
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
