mena661 wrote:
Side note, I just noticed that 80A only goes to 14V. Might have to get that adjustable Powermax instead. So, I can just let Vabs run till 0 amps with no shot of 15+V at the end to get it topped off?
I use the mod 100 at fixed 14.8 but after that I use the VEC to do any topping off/equalizing.
I imagine that external pot 100 will cost twice what the old PM3-100s cost now, but you have to take the top off the old one and twiddle the tiny blue pot with a tiny screwdriver and not blow anything up. Then put the top back on and leave it be. (or every time you twiddle it you have another chance to break that tiny thing)
If it is true they will limit the external knob 100 to 15.5v then you will still be using the VEC anyway. I tried my external 100 set at 15.5 (highest mine will go) and it acted the same as the VEC pretty much, with amps about 4 starting off and then tapering. So about 4 is the natural acceptance rate for a pair of 6s at 15.5 I guess.
I gather Mex wants one that you can set your 5% worth of amps on it and ease the voltage on up to keep the amps the same as the equalize runs on. Very hands on.
These things I /we have can only do a constant voltage and amps will taper. Still, I have no problem getting the SG to baseline doing that with my 6s and I am nowhere near 5% amps at first and they taper.
OTOH I never did get my old T-1275s equalized. Their cells are all over the place, but the batts are doing great. I just have a baseline for each cell which I keep score on. Oh well.
