dougrainer
Mar 17, 2018Nomad
How LONG are you holding the button in when the green indicator is showing. I have found, that you may have to hold it up to a minute. If so, then the Nut on the Thermocoupler is NOT tight. Usually, just a 1/4 turn on the nut will restore the millivolt connection. You do have to partially pull the refer to do this. Doug
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
