dougrainer
Mar 16, 2020Nomad
When I see posts like this, how come NOBODY ever questions HOW Jayco connects the wire to the Battery? I am talking about a 30 amp ATC fuse holder with 14 gauge wire pigtails. Kind of like having a 1 inch water line connected to a 1/4 inch hose to the input of your house. Kind of negates the purpose of getting all the power you should require. You need to replace the input fuse system to your battery also. Jayco runs a 12 gauge wire from the positive battery post 2 feet to a 14 gauge 30 amp ATC fuse with the pigtails about 4 inches long in and out. Also, I don't think Jayco runs a dedicated GROUND wire to the Converter. The ground goes from a Chassis frame stud below the Converter area to the Frame. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
