landyacht318
Mar 17, 2020Explorer
dougrainer wrote:
When I see posts like this, how come NOBODY ever questions HOW Jayco connects the wire to the Battery? I am talking about a 30 amp ATC fuse holder with 14 gauge wire pigtails.............
A while back I bought a bunch of supposed 10AWG ATC inline fuse holders. They were 12 gauge SAE at best, and SAE wire gauge is 6 to 12% thinner than AWG
I had acquired them to bypass the original HVac blower motor fuse, which like many vehicles, the whole circuit is underwired, and for other things. The original fuse holder had melted before my ownership of the vehicle and the previous owner had used a glass inline fuse holder instead, which lasted me all of 3 or 4 months before melting.
It worked for about 7 months, and one day with blower motor on speed 3 of 4, I started smelling burning plastic, and turned off blower motor. I later found the fuse holder was completely melted around the 20 amp fuse.
Later I got '8 AWG' Maxi fuse holders and when installed on this circuit, no more issues, not to say that these are built any better, but at least 8awg can wick away the heat from the fuse tang connection better. Where that wire joins inside the plastic molding is a huge resistive point.
Not too long after that the blower motor started squealing, and the speed switch lever itself had been getting hot. On inspection I found The wires entering it were charred. I replaced everything including resistor pack, and used 8awg overkill from speed switch to new blower motor, and the amount of air the motor moved on high was at least 20% more and no more issues.
More recently I decided to use a 40 amp 21khz PWM motor speed controller instead of the resistor pack for speed control, and ran a new 8awg power feed to dash so I can power it with Key not in the ignition. I've not yet tested the voltage reaching the motor now, but it has to be considerably higher, and the amount of air exiting the vents at highest speed, has improved yet again.
I feel better the whole underwired original circuit is basically offline, but still functional, all I have to do is open the glove box and switch an anderson powerpole, but see no reason to do so.
I actually wish I did not bother rebuilding the speed switch and part of the Hvac circuit, but just went for the PWM motor speed controller at that point.
Infinite fan speeds engine on or off , ignition on or off, and much less wasted amperage bypassing the resistor pack speed control. The blower motor is not as efficient as my other methods( computer fans) for exchanging outside for inside air when parked, but it is a very nice option to have.
The vents are vaccuum operated and will revert to windshield/defrost and floor, rather than the dash, about 5 minutes after engine shutdown.
Where the air exits, as well as the position of the blend door, affects amp draw of the motor.
Twice, I have had to open up the new blower motor as the brushes got stuck inside their holders, the second time I reduced their dimensions. Nice quality control there.
Anyway, almost all the inline fuse holders I have purchased are problematic even on circuits well below the wire rating, and some Rv manufacturer using these inline from the converter is criminal batterycide incompetence.
I now make my own inline ATC fuse terminals with 10AWG and 10-12 insulated flag terminals, or lesser flag terminals on lesser wire. I crimp then solder then slide the insulation back over the terminal, then Use Amazing goop around the flag terminals to form a one piece body.
I trust these, and they are low profile and way better than any purchased inline fuse holder with the two extra connections required to butt splice them into the wiring.
I have employed the other '10 awg' ATC fuse holders on other circuits that rarely see more than 10 amps and only briefly, but they will be phased out.
Unfortunately they do not sell 8awg flag terminal quick connects in order to grasp the tangs of a Maxi fuse, and I have had to use the older inline 8awg fuse holders on my new 8awg dash feed, but intend to phase it out at some point.
The Blower motor draws 50% more current when it gets 14.5v vs 12.6v and spins way faster too, and I doubt the original circuit ever fed it more than 10.5v even when the alternator had system voltage upto 14.9v.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
