- CruiseomaticExplorerBoth JB weld and drywall clamps sound really good. Think I'll do both. Where I have excess holes, fill them with weld and on the original use the clamps. Even for a Fema trailer this is sad. One re-drill and its done. But, The build quality is showing better than anything Fleetwood could do. I know, I used to have one. Thanks guys.
- LockyExplorerTheres numerous ways to do this. A couple already said above or try using the next size up screw and if that doesn't work then fill the holes with your caulk then install the lights with your screws even though they are stripped. Now caulk around the light like you would normally have. Once the caulk drys you will be fine.
- mydazeoffExplorerFill the hole with JB Weld and re-drill. Another option is to use a plastic dry wall insert, the type used for hanging stuff on a wall. Just make sure to use plenty of sealant.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 22, 2026
