I have a 92 thor pinnacle 454 engine.I have a brake light lit up on the instrument panel.I went to check the fluid but couldnt find the master cylinder anywhere.I ran the lines from the caliber to the...
As J-D said, an imbalance in the hydraulic system, either from low fluid which can be caused by disc pad wear, or an internal leak will cause the brake warning light to come on. If you find tha fluid is low, be sure to find the cause, don't just add fluid and be done. If the fluid isn't low, it's probably an internal leak, and the master cylinder needs to be replaced. JMHO
