I have a 92 thor pinnacle 454 engine.I have a brake light lit up on the instrument panel.I went to check the fluid but couldnt find the master cylinder anywhere.I ran the lines from the caliber to the...
Auto park applies the parking brake when shift lever goes into park. You have separate lights, so that should not be the problem. There is a switch for the brakes down on frame rail below the master cylinder. Check to see if the wire has come off or has melted from being close to the exhaust manifold.
