I have a 92 thor pinnacle 454 engine.I have a brake light lit up on the instrument panel.I went to check the fluid but couldnt find the master cylinder anywhere.I ran the lines from the caliber to the...
No, the brake indicator is on the brake fluid system. Yes, low power steering fluid can effect braking. I didn't see a reply as to whether you have drum or disc brakes in the rear. Does your master cylinder have one or two lines exiting it?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
