I have a 92 thor pinnacle 454 engine.I have a brake light lit up on the instrument panel.I went to check the fluid but couldnt find the master cylinder anywhere.I ran the lines from the caliber to the...
I have front and rear disc brake.I am not sure about the lines but it has two seperate bowls in the master cylinder.I filled the steering fluid but it didnt turn the light off.Now i am trying to find the test port to ground the a and b port to start a troubleshoot with the check engine light.I cant seem to locate the test port.Do you have any idea where it might be?It is a 92 thor pinnacle on a p30 chassis with 454.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
