wa8yxm
Oct 08, 2020Explorer III
What are you powering with them.. Generally the max amp draw for an RV WITHOUT an inverter is not that great. Each 1141 light bulb is about .8 amp (Figure 1 amp to make the math easy) plus Furnace draws about 3.5 amps. Fridge if 12 volt up to 20 (don't use that option) on AC closer to 2 or 3.
Add 10 amps for "Misc" and you have it
Replace the light bulbs with LED divide by 10 (1 becomes 0.1)
INVERTERS 100 amps per 1000 watts.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
