red31
Aug 16, 2017Explorer
Trojan, up to 20%, when queried no limit but temp and $
http://www.trojanbattery.com/Tech-Support/FAQ/Charging.aspx
"What size charger should I buy?
A properly sized charger takes into account battery capacity and the time interval between charges. In applications where cycling is infrequent, such as weekend RV users, or infrequent or seasonal trolling motor usage, a charger with an output current rating between 10 and 13% of the battery's rated 20-hour capacity will suffice. In applications where battery recharge must be accomplished within 8 to 10 hours, a three stage, automatic charger, rated at 20% of the battery capacity, may be required.
Example: A good charging rate for a battery with a 20-hr capacity of 225 amp-hr is about 22 to 29 amps. You can of course go slightly higher or lower depending on what is available on the market."
