MainerBob's avatar
MainerBob
Maxair fan demise?
We have a maxair fan up over the bed. Recently it stopped working while turned on. I turned it off and removed the fuse. It was hot enough to burn my fingers. I took down the screen and tried to spin it by hand and it spins easily. I cleaned the screen and replaced it and put the fuse back in - same thing. It runs for a minute or so and then slows and stops. Then I discovered that if I hold the black fuse cap all the way up all is good. It works fine, but when I let go the fuse comes out about 1/8" against a spring and slows and stops along with heating up the fuse.
I can't see any way to replace the fuseholder. Can I just put a little ball of aluminum foil in the cap so the fuse fits tighter? I think that would work but would it be safe?
It is the correct 4A fuse. This is original to the rig and never a problem before.
  • Don't wrap the fuse in foil but if you put a bit of foil in one end of the fuseholder to make up the space you should be fine. Once you do and it's working properly just double check to make sure it is not heating up. If it still does then you need to stop using it right away until you can get a replacement.
    Should work, but I would talk to Maxair. They should replace the fan for free.
  • Bumpyroad wrote:
    ask maxxaire for advice. can you put a longer fuse in that holder? but why so hot?
    bumpy
    Because the fuse was loose and making poor contact in the fuse holder. The poor contact causes the connection to generate heat the same as a loose wire will do.
  • ask maxxaire for advice. can you put a longer fuse in that holder? but why so hot?
    bumpy
Having RV issues? Connect with others who have been in your shoes.24,233 PostsLatest Activity: Apr 10, 2025
