Keep in mind a typical 120WATT SOLAR PANEL will only produce 5-6AMPS when in HIGH SUN... Two solar panels in parallel will only be 10-12AMPS DC Current.
My battery bank is rated at 255AHs and will demand 52-53AMPS DC CURRENT when 14.4VDC is first applied for boost charge mode. This will start tapering back down to around 8AMPS DC Current with-in 15-30 minutes time or so.. To get my battery bank charged back up from 50% charge to 90% charge I will need to charge them using 14.4VDC for two hours and then 13.6VDC for an additional hour to get the battery bank back up to its 90% charge state.
I have to run my camper shore power connected to my 2kW Generator in order for my on-board converter/charger unit to get this accomplished in a three hour generator run time.
If I had solar panels installed I could run the generator first for one hour to get past the initial high 52-53AMPS DC Current demand and then just use the solar panels after the Battery Bank DC CURRENT DEMAND has tapered back to around 8AMPS DC CURRENT.
In my case I will not use my battery bank again until it is at least back up to its 90% charge state. Otherwise in my case I lose battery performance real quick and this will also do damage to my battery battery bank if I do this as a routine.
