nuckfan's avatar
nuckfan
maximizing battery capacity
I have an 8 foot camper with a 100 watt solar panel and charger. Right now I have a group 24 12v battery and would like to increase the amp hr capacity, I was wanting to run two 6v in parallel but I cannot due to the size of the battery box being too small. the opening on it is 14.5" wide by 20" tall and 9" deep. What I would like to know is what type of battery can maximize the amount of amp hours given the limitations I need to deal with.I have looked at Interstate batteries but cannot find one that is not rated in cold cranking amps, as I was informed that this would not be an ideal application for a solar setup.
  • When I upgraded my Grp 24 to a Costco Grp 27 Marine/RV battery, I went from 75AH to 115AH. And I think there are Grp 29 and 31 above that.
  • The common 12 volt battery group sizes do differ in physical size and capacity.
    For instance, here's a Group 27 deep cycle 12 volt battery:
    http://www.fullriverbattery.com/product/batteries/DC105-12
    And here's a Group 31 deep cycle 12 volt battery of the same series by the same manufacturer. Note that it has larger physical dimensions and greater capacity:
    http://www.fullriverbattery.com/product/batteries/DC115-12
    Both of the above two diffferent group size batteries have the same type of terminals.
  • I have to say for myself anyway I find it a bit overwhelming how much there is to learn about an rv electrical system when solar is involved. Thank you Almot for dumbing it down for me a bit. I now have a better understanding and see that I do have some options for more battery capacity given the limitations of room I need to endure. The Torklift battery cradle thing is an idea but might be a hinderance when going off-road. I like the idea of AGM because the can be mounted on their side making the best use of space in my battery house. Too bad lithium batteries cost so much. Ton of amp hours in a smaller lighter package but cha-ching$$$
  • Almot's avatar
    Almot
    Explorer III
    Lithiums and AGM are 2 different things.
    If you can squeeze 2 AGM on its side for a total 200-220 AH, with moderate energy use and 200W solar you'll be OK. Can present technical difficulties though. The battery sides are not always perfectly flat.
    Don't cheap out on AGM, get some reputable brand. Lifeline may not be the best choice for the reasons that people noted. Deka is a decent brand too, and costs less.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
