brianokeefe
Jul 19, 2017Explorer
adding to coach battery capacity
Hello All
I have a 1990 Warrior on the 1 ton Toy chassis. I do not have a working generator and even if the old Tecumseh I do have ran (died 8 months ago) I wouldn't want to use it as it's smoke blowing rattletrap compared to new models out there. I also don't want to haul a portable and the fuel for it at that would be on the rack at the rear.
So I'd like to beef up the coach battery capacity. The current battery is less than a year old and rated at 100 ah. I have a 4K W inverter it's hooked to and it will run a piece of med equipment I need for about 6 hours. I'd like 8-10 hrs. I thought of getting a small, sealed AGM battery that I could put inside the coach and connect it to the inverter too so that all 3 components would be wired together and the batteries would charge when driving. The smaller battery that I'v found is 35 AH. There seems to be a question among the people I've asked as to whether the smaller battery would just diminish the overall AH when I operated the coach from batteries only. So I thought that I could just connect the smaller battery to the inverter where the larger battery already is connected and everything would be happy and I'd get longer juice production.
Can anyone give me an answer on this? Many,many thanks
