brianokeefe
Jul 20, 2017Explorer
I can try and find 6V batteries of the size that will fit in my limited compartment space. It just fits the current 12V deep cycle one. I could get 2 larger (dimension) in which one fits into the battery compartment and one I could put in the closet and connect them in parallel. If I did that by connecting both to the inverter, thus they'd only charge or do nothing than run the 12V coach system, if the inverter isn't on. Is that a solution? Sort of loath to replace the inverter because 1) it was expensive and 2) it will run a toaster, coffee maker and even a toaster oven.
