theoldwizard1
Aug 18, 2017Explorer II
BobsYourUncle wrote:
Most important consideration is that the batteries are all of same strength. Don't mix old weak ones with new strong ones. Weak will sap strong.
CONCUR !
I would also add, flooded cell batteries are probably better because you can use a hydrometer to test for individual cell strength. It is important that they all equal,
time2roll wrote:
Technically you can have as many as you like but the chances of trouble start increasing. To keep them balanced you may need a bus. As a minimum attach the main feed vs ground at each end of the stack.
I don't know that physical type/style of connection really matters as long a it is adequate to handle the current.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
