full_mosey
Aug 29, 2018Explorer
pianotuna wrote:
Hi,
I was toying with my charge voltages. I wanted to try 15.4. When I set 15.4 on the remote it did not get above 14.7 volts. The bank was fairly full so it was only doing between 8 and 10 amps of charging.
Do you have a Voltage cap set? The cap might be lower than the 15.4V Abs you are trying with the result that your cap setting is overriding.
Does your Battery-Temp-Sensor work. I did once have a faulty one from Magnum. It could have been the circuit board though as I ended up exchanging the entire inverter and BTS cable.
HTH;
John
