pianotuna's avatar
pianotuna
Nomad III
Aug 27, 2018
maximum dc voltage output Magnum 3012 with remote
Hi,
I was toying with my charge voltages. I wanted to try 15.4. When I set 15.4 on the remote it did not get above 14.7 volts. The bank was fairly full so it was only doing between 8 and 10 amps of charging.
Does anyone know the maximum dc output voltage?
  • Try 14.9 next time you run them down a bit. Is there a second limitation by battery type etc? Maybe reduce the amp rating to 50% of max.
  • If your battery is at or near charge capacity of 14v, your voltage will be regulated down from 15.4volts. If your battery was sitting at a lower capacity such as 10volts when you would see higher charging output voltage. This can usually be confirmed by using a volt meter while briefly disconnecting the positive lead from the charging source simulating a fully discharged battery. This would command 15.4v max charge. Running the charger like this for an extended time could cause damage.
  • Hi,
    The banks were at 19.5 C, so I think it is not temperature related.
  • It may have been limiting due to temperature. I know those will do well over that voltage for equalization.
Having RV issues? Connect with others who have been in your shoes.24,205 PostsLatest Activity: Feb 23, 2025
