BFL13
Oct 20, 2014Explorer II
If your charger only does 40a, then on two 27s, it will take about two hours to do a 50-80. If you keep going, then in another hour you will get from 80 to 90. Three hour 50-90.
I would prefer a two hour 50-90 but that takes a 70 amp charger on two 27s, which will accept that perfectly.
The PD/Onan issue just means the PD will do fewer amps but not that many less.
One way to solve this would be a PowerMax 75a adjustable voltage model from Randy, but first make sure it is PF corrected so it can run on a 15a circuit, then consider the cost. You can do anything if money is no object!
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
