Snowman9000
Oct 21, 2014Explorer
MEXICOWANDERER wrote:
The object here is for the optional PS to take over when the P.O.S. OEM converter decides to lean on a shovel, right?
No. I want it to be the initial, bulk charge. Only for those times when I charge from a genset, up to two hours or so. From what I've been reading, it sounded like the p.s. would actually outperform any of the converter chargers for the first two hours of charging. Am I wrong about that?
A Mega will do fine. Set the voltage to 14.8 Two hour of "BOOST" at 14.4 will deliver around 60 to 70 amp hours. When it drops back to "NORMAL" at 13.6 the game is all over. The batteries are going to laugh at that unless you use a sundial as a timer. This is where a power supply kicks in and fills the gap at 14.8 volts.
I'm not sure if you are saying using the Mega for the first two hours, or for two hours beginning after my converter drops to 13.6V. BTW I currently have WFCO, so 13.6 is probably the most it will ever do.
So am I on the wrong track?
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
