Snowman9000
Oct 21, 2014Explorer
NinerBikes wrote:
I am the original early adopter... I bought a Mega Watt for $55. I have one 150 AH battery. That's a hair less than a pair of Group 27s DC's....
NB, can you describe what happens as far as volts and amps over a two hour period? And also if you let it run for longer?
What I'm asking is, does it behave as a constant current charger at first? Sending max amps, while the voltage rises through the 13's, and topping out at 14.8?
Then, does it taper amps while holding 14.8? (Constant voltage)
If left on for 24 hours, would it taper amps down to next to nothing while staying at 14.8v? I don't plan to do that, but I want to understand how it behaves.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
