MEXICOWANDERER
Oct 21, 2014Explorer
This is from the Power Max 75 Site
75 amp 3 Stage Charger
KEY FEATURES:
Automatic three-stage battery charging maintains your battery's life with three nominal voltage output models:
* 13.2 Vdc range "float" mode
* 13.6 Vdc range "absorption" mode
* 14.4 Vdc range "bulk" mode
* Electronic current limiting automatically shuts down power during overload or short-circuit conditions.
* Quiet operation in a wide range outputs. Convenient deck mount installation.
The PM3-75 Amp converter/ charger is a versatile, advanced power source solution.
Some of you are familiar with this unit. Voltage rises slowly as batteries charge to 14.4 volts. After this unit reaches 14.4 volts how long does it stay at 14.4 volts before it decides to do something weird?
-An Educational Moment-
KEY FEATURES:
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
