BFL13
Oct 21, 2014Explorer II
jrnymn7 wrote:
For example, on a 215Ah bank at 50%, it will start around 13v / 46a. During the 15 minute thing, volts will rise to about 14. The unit shuts down, then comes on and continues from where it left off. At some point later (I would have to check my notes) amps will begin to taper, but the volts might be somewhere around say 14.3. The volts finally get to my 14.8 setting right around the time amps level out.
So it starts at 45a stays there for 15 minutes, then restarts at 45amps and stays there till it starts to taper? Before, you seemed to say it tapered the amps right after the 15 minutes when starting at 50% SOC. Which is it?
The voltages you are quoting looks more like the Vector's profile where it tapers closer to 14v, but then voltage continues to rise while amps taper. See that ugly graph again where it shows the Vector amps and volts. Note the Vectors beat the PM3 set at 14.6 but now the PM3 is at 14.8 they are about equal for time to do a 50-90.
Edit--yes like the 1093 which is a Vector profile
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
