jrnymn7
Oct 21, 2014Explorer
BFL13 wrote:jrnymn7 wrote:
BFL: Which is it?
It was both:
pre-mod it would not recognize the batts were still down around 55%, so amps would taper.
post-mod it doesn't seem to understand what cv means.
So if it stays at 45 amps till voltage reaches about 14.3 when amps then taper and voltage carries on up to 14.8 by the time voltage is down to zero, you can use that. Just declare Victory now before they attack again :)
You can still use the 5 amps per battery marker to stop the charge at 90% SOC with voltage about 14.5.
Did you mean when voltage drop reaches zero, not volts???
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jul 12, 2016
