jrnymn7
Oct 22, 2014Explorer
FWIW, Mine works well for me, even though the unit never functioned properly from the get go. I have it set at 15.8v. It comes on about 13v (on 50% batts) and gets to a little under 14.8v at about 8a, if I recall. And after it has sat for an additional couple hours at 14.8v, I can also adjust it up even higher, while it's charging, and do a top charge at 15.2v.
And I guess I could use it to float, if absolutely necessary, by simply dialing it down to a suitable float voltage. Worse case scenario, if the power did go off and on, it would float at 1v higher for 15 minutes, and then drop back down... no biggy!
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jul 12, 2016
