Snowman9000
Oct 22, 2014Explorer
BFL13 wrote:Snowman9000 wrote:
BFL, on the PM3, how did simply adjusting the voltage pot make it hold the full voltage in absorption, and also no longer float? Or do I have that wrong?
I don't know how it does it :) The procedure is to plug it in on bench no load with multimeter in the output. You will see it says 13.6. turn that up to 14.8. put the lid back on. done.
Now when you start the recharge from any SOC , it will bring the battery voltage up to 14.8 (Bulk Stage) and then it stays at 14.8 while amps taper. (Absorption Stage) that's it.
I don't know if it will ever float after a long time at 14.8, since I never leave on that long. I suspect all the voltages will rise when you crank up the pot. On the Paramode, which also has that internal pot, when I cranked that up to 14.8 (from 14.2) it also raised the float voltage from 13.6 to 14something, forget number.
Well that sounds ideal for a fast genset charger. Is there a question about the durability, then?
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
