BFL13
Oct 22, 2014Explorer II
MEXICOWANDERER wrote:
BFL I sure wouldn't want to be stuck with only one charging source that has a top end of 14.4 volts.
The supplemental chargers should be employed when on generator power. Do a check on a 4 battery bank and see the amperage differential between 14.4 and 14.8 volts.
Yes, I put mine to 14.8 when it was too slow at 14.6. I was just looking at alternatives for the OP since he was wanting his to go to Float and the modified PM3 won't.
The OP was also looking at the power supply Mex was showing us, so he is in 'research mode' I guess.
The OP is also getting solar, so he can find higher voltages there if he gets an adjustable voltage controller. Can follow some gen time with some solar time if the weatherman allows.
I use several different chargers in different circumstances to get there. None of them is able to "do it all."
Once you do buy something, you try to make it work even if it won't
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
