Snowman9000
Oct 22, 2014Explorer
BFL13 wrote:Snowman9000 wrote:
No, I am NOT looking for float!
I'm looking for a charger to put in a lot of AH in 2 hours of run time on an Onan genset. Period.
I gots float otherwise covered.
And equalizing too.
I gots confused by you asking so often whether the mod PM3 did float. :)
The tangents make it hard to keep up.
I was trying to make sure I understood what it does and doesn't do. It sounds like it would do what I want: Full amps till full volts reached, then hold the volts while amps taper. Unless it's now unreliable or flaky in some way? I would retain the regular wfco converter for converting, float charging, etc.
