Snowman,
When Mex said... "A Mega will do fine. Set the voltage to 14.8 Two hour of "BOOST" at 14.4 will deliver around 60 to 70 amp hours. When it drops back to "NORMAL" at 13.6 the game is all over. The batteries are going to laugh at that unless you use a sundial as a timer. This is where a power supply kicks in and fills the gap at 14.8 volts"... he was indeed referring to two different units.
My apologies, I should have made the comparison between the language used for 3 stage chargers, compared with the language used to describe the workings of a psu. Keeping in mind, a 3 stage charger is a psu:
Constant current is called "Boost/Bulk/etc" mode when referring to 3 stage chargers. Likewise, constant voltage is called "Absorption/Normal/Finishing/etc" mode. But it's all the same charging sequence.
Mex said, "The object here is for the optional PS to take over when the P.O.S. OEM converter decides to lean on a shovel, right?"
I don't think mex was being literal here, but referring to replacing the CONVERTER with a CHARGER, and in this case employing a psu as your charger. Converters are great at providing 12v power to your rig for 12v lighting, etc., but the 'charger feature' that comes with these converters are generally set to too low a voltage for charging OFF GRID. Most 'boondockers', such as yourself, would prefer not to run their genset for hours on end, just to charge their batteries. And this is not an unreasonable expectation by any stretch. Moreover, it easy to achieve such a goal by simply using a charging source that can be adjusted to a more realistic voltage. A simple solution to a simple problem.
Unfortunately, truth and myth are often skewed by marketing misinformation (perhaps even dis-information?) and urban legend. The myth, in this case being, deep cycle batteries like to coddled and suckled like babies, when in fact they are hungry as hell, and need a decent meal. For example, some here will insist their Trojan T-105's "like" to be charged at 13.6v. It occurred to me that these folks must be doing some sort of Mr. Spock Mind Meld on their batteries, to acquire such intimate knowledge, when in fact Trojan, themselves, recommend a daily 14.8v charge. You will no doubt encounter folks who simply cannot let go of the myth and get a grasp on the reality that charging at higher voltages will NOT kill your flooded lead acid batteries. Yes, over charging will kill your batteries, but no one here is suggesting any such thing. In fact mex's timer suggestion is proof positive of this.
Yes you are on the right track... you want to charge your batteries within a reasonable time frame; which simply cannot be accomplished using a converter with a charge feature set to a low voltage. And yes, 14.4v will make a significant difference over 13.6v, but then again, so will 14.8v over 14.4. The example I gave comparing a 60 amper to a 40 amper was using the same 14.8v setting. But try using that 40 amper at 14.4v boost/cc, followed by 13.6v abs/cv, and watch your charge time rise to closer to 8-10 hours.
Hope this helps to clarify things.
