landyacht318
Oct 08, 2014Explorer
Look at the RSP-1000-15 instead. That should be good for 80 +amps DC since my rsp-500-15 will do 40.94 amps DC until battery voltage rises to within 0.3v of what I set the voltage at before connecting it to the battery.
http://www.meanwell.com/webapp/product/search.aspx?prod=rsp-1000
You probably could get one of those Shottkeys diodes and perhaps run your Megawatt in parallel with it on the same circuit for 110 amps into that 740 AH L16 bank.
http://www.allelectronics.com/make-a-store/item/cpt40045/400a-45v-schottky-powermod-rectifier/1.html
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
