mena661
Oct 09, 2014Explorer
I think Randy's asking $275 for the Powermax 100A. There's no stages, you are the stages. :)
ken white wrote:That's true. I would only be using the low 15V range at most (it would be in the high 14's for charging) so I should be under it's max draw.
Don't operate it at its maximum output current and it will work fine.
It may even work at or very near maximum output current since its specifications are so close to 15 amps...
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
