MEXICOWANDERER
Sep 25, 2014Explorer
1/4" X 28 stud. Stem is positive stud in negative.
Needs to be thermally bonded to a heat sink. use
You can find TONS of heat sinks with a 5/16" hole already drilled online at surplus electronic supply places.
The mounting kit insulates the rectifier from the case electrically so the heat sink remains with no voltage. Solder incoming power from power supply to stem of rectifier. Bolt eyelet terminal to lead whose wire goes to battery positive.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
